BackyardEOS 3.2 Trial Edition [OTL-BYE-T]
OTL-BYE-T
Free
BackyardEOS is software tailor made to control your Canon DSLR camera. It is purposely built with astro-photography in mind.
This highly acclaimed software is in use all around the world by thousands of users. Its intuitive user interface caters to the amateur and seasoned astronomers alike. Program your image capture plan and walk away. BackyardEOS will control your Canon DSLR camera and deep sky long exposure images all night long.
BackyardEOS is Windows only software!
BackyardEOS is downloadable software only!
Here is a 2 hour 41 minutes presentation on BackyardEOS by its creator.
About BackyardEOS 3.2 Trial Edition [OTL-BYE-T]
Supported Cameras
BackyardEOS supports over 40 Canon EOS camera models!
When you see (serial) for a particular function, it means a serial cable is needed to access that function in addition to the regular USB cable for all other functions. BackyardEOS has been tested with Shoestring Astronomy DSUSB serial cables and Hap Griffin's serial cables.
Name Processor Live view Sensor Temperature Bulb Mirror Lock Operating System Tested
1Ds Mk II DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
1D Not supported
1D C Non-DIGIC DV No No Yes (serial) Yes (serial) W11 (32 bits) Yes
1Ds Not supported
1Ds Mk III DIGIC III Yes Yes Yes (usb) Yes (serial) W11 (32/64 bits) Contact Us
1D Mk III DIGIC III Yes Yes Yes (usb) Yes (serial) W11 (32/64 bits) Yes
1D Mk IV DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
1Dx DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
1Dx Mk II DIGIC VI+ Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
5D DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
5Ds DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
5DsR DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
5D Mk II DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
5D Mk III DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
5D Mk IV DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
6D DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
6D Mk II DIGIC VII Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
7D DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
7D Mk II DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
10D Not supported
20D DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
20Da DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
30D DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
40D DIGIC III Yes Yes Yes (usb) Yes (serial) W11 (32/64 bits) Yes
50D DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
60D DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
60Da DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
70D DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
77D DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
80D DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
90D DIGIC VI Yes Yes Yes (usb) No W11 (32/64 bits) Yes
100D / SL1 DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
200D / SL2 DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
250D / SL3 / 200D MkII DIGIC VIII Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
300D Not supported
350D / XT DIGIC II No No Yes (serial) Yes (serial) W11 (32 bits) Yes
400D / XTi DIGIC II No No Yes (serial) Yes (serial) W11 (32/64 bits) Yes
450D / XSi DIGIC III Yes Yes Yes (usb) Yes (serial) W11 (32/64 bits) Yes
500D / T1i DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
550D / T2i DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
600D / T3i DIGIC IV Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
650D / T4i DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
700D / T5i DIGIC V Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
750D / T6i DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
760D / T6s DIGIC VI Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
800D / T7i DIGIC VII Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
850D / T8i DIGIC VIII Yes Yes Yes (usb) Yes (usb) W11 (32/64 bits) Yes
1000D / XS DIGIC III Yes Yes Yes (usb) Yes (serial) W11 (32/64 bits) Yes
1100D / T3 DIGIC IV Yes Yes Yes (usb) No W11 (32/64 bits) Yes
1200D / T5 DIGIC IV Yes Yes Yes (usb) No W11 (32/64 bits) Yes
1300D / T6 DIGIC IV Yes Yes Yes (usb) No W11 (32/64 bits) Yes
2000D / T7 DIGIC IV Yes Yes Yes (usb) No W11 (32/64 bits) Yes
4000D / T100 DIGIC V Yes Yes Yes (usb) No W11 (32/64 bits) Yes
EOS-M / M2 / M3 / M4 / M5 / M6 Not supported
EOS-M6 Mk II DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-M50 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-M50 MkII DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-M200 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-RA DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-RP DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R5 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R6 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R6 MkII DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R7 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R8 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
EOS-R10 DIGIC VIII Yes Yes Yes (usb) n/a W11 (32/64 bits) Yes
Compare Editions
General Ambient weather center logging Non Yes Yes
Licensing Time limited Non Non 30 days
BackyardEOS upgrade instructions
If you have purchased BackyardEOS in the past chances are you can upgrade to the most latest version/edition for free.
You need an account first!
I already have 3.1 and I just want the latest release. What do I do?
Upgrading from BackyardEOS 3.1.x to the latest 3.1.x is FREE.
What do I need to do?
If you currently own BackyardEOS 3.1.x and simply wish to get the latest version of that same edition there is no special upgrade path; simply download the latest version, install, use the same key, and enjoy!
How-to upgrade from BackyardEOS 1.x or 2.x to BackyardEOS 3.1 Classic or Premium Edition?
Upgrading from BackyardEOS 1.x or 2.x to BackyardEOS 3.1 Classic Edition is FREE.
Upgrading from BackyardEOS 1.x or 2.x to BackyardEOS 3.1 Premium Edition is $15 USD.
What do I need?
You need your 18-line BackyardEOS 1.x license key.
What do I do?
  2. Send us your complete 18-line version 1.x or 2.x license key. Contact Us.
  3. We will send you a coupon code, this may take up to 24 hours.
  4. Go to our store and add BackyardEOS Classic Edition in your cart and proceed to checkout.
  5. Enter your coupon code on the checkout page.
  6. Your new activation key will be issued ONLINE immediately once the transaction is complete.
  7. Download, install, enjoy!
What if I want Premium Edition instead?
Just add the Premium Edition in your cart instead of the Classic Edition and use the same coupon. You will have to pay the cost difference.
How-to upgrade from BackyardEOS 3.0.x Classic Edition to BackyardEOS 3.1 Classic or Premium Edition?
Upgrading from BackyardEOS 3.0.x Classic Edition to BackyardEOS 3.1 Classic Edition is FREE.
Upgrading from BackyardEOS 3.0.x Classic Edition to BackyardEOS 3.1 Premium Edition is $15 USD.
What do I need?
  1. You need your 5-line BackyardEOS 3.0.x license key.
  2. Your coupon code is the first 25 characters of your 5-line BackyardEOS 3.0.x license key, including dashes.
  3. It looks something like this QS3ER-5RTE4-WE3GR-3RG65-9.
What do I do?
  2. Go to our store and add BackyardEOS Classic Edition in your cart and proceed to checkout.
  3. Enter your coupon code on the checkout page.
  4. Your new activation key will be issued ONLINE immediately once the transaction is complete.
  5. Download, install, enjoy!
  6. What if I want Premium Edition instead?
  7. Just add the Premium Edition in your cart instead of the Classic Edition and use the same coupon. You will have to pay the cost difference.
How-to upgrade from BackyardEOS 3.0.x Premium Edition to BackyardEOS 3.1 Premium Edition?
Upgrading from BackyardEOS 3.0.x Premium Edition to BackyardEOS 3.1 Premium Edition is FREE.
What do I need?
What do I do?
  2. Go to our store and add BackyardEOS Premium Edition in your cart and proceed to checkout.
  4. Your new activation key will be issued ON-LINE immediately once the transaction is complete.
How-to upgrade from BackyardEOS 3.1.x Classic Edition to BackyardEOS 3.1.x Premium Edition?
Upgrading from BackyardEOS 3.1.x Classic Edition to BackyardEOS 3.1 Premium Edition is $20 USD.
What do I do?
  3. Enter coupon code 'BYE-UPG-PREMIUM' on the checkout page.
LIMITED WARRANTY
LIMITATIONS ON LIABILITY
GENERAL PROVISIONS
