Explore Scientific 100° 20mm [ES-EPWP10020-00]
ES-EPWP10020-00
$619.06 CAD $814.55 CAD
2 in stock On sale IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Explore Scientific:Explore Scientific eyepiece, 20 mm focal length, 100 ° field of view, 50.8 mm (2 ").
A few years ago, Explore Scientific eyepieces have developed a solid reputation in terms of quality, The eyepiece of Explore is a pleasant and easy experience, the image is beautiful from the first glance.
This eyepiece offers an apparent wide field of 100 °, high level optical quality, surprising light transmission and correctly corrected field planarity ...
Each eyepiece of the 100 ° series is sealed and filled with an inert gas, argon. This process prevents the formation of condensation inside the eyepiece and prevents the entry of dust to maximize the lifetime of the internal coatings. To ensure watertightness, each eyepiece of the 100 ° series is factory tested by immersing it under water for 30 minutes to a depth of one meter.
All 100 ° eyepieces are fully multilayered and the edges are blackened to produce maximum contrast.
The Explore Scientific 100 ° delivers sharp, contrasting images. The apparent field of 100 ° is so wide, that you can keep in sight a celestial object observed in a non-motorized instrument.
The focal length of the 20 "Scientific Explore Scientific eyepiece predestines it at low magnifications (47x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The eye relief of 20 mm is 14.5 mm: this means that the image remains comfortable up to a distance of 14.5 mm above the lens, to take full advantage of the field offered by the lens, ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
The inside of the sink is threaded in M48 x 0.75 mm to accommodate 50.8 mm (2 ") diameter filters, Such as interference filters of type OIII, UHC, H-Beta..., Which serve to enhance the contrast on many nebulae
About Explore Scientific 100° 20mm [ES-EPWP10020-00]
  • Description    Explore Scientific 20mm 100° Series
  • Item Number    EPWP10020-00
  • Focal Length    20mm
  • Length    156mm
  • Width    70mm
  • Weight    38.1oz; 968g
  • Barrel Size    2.00”
  • Eye Relief    14.5mm
  • Field Stop Diameter:    34.8mm
  • $52.00 CAD - [S1] USPS Ground Shipping (7-21 days)
    7 in × 7 in × 6 in
    3 lb
