Explore Scientific 100° 25mm - 2" [ES-EPWP10025-01]
ES-EPWP10025-01
$954.66 CAD $1,256.13 CAD
2 in stock On sale IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Explore Scientific: Explore Scientific Eyepiece, 25 mm focal length, 100 ° visible field, 2"( 50.8 mm).
This eyepiece offers an apparent wide field of 100 °, high level optical quality, surprising light transmission and correctly corrected field planarity ...
Each eyepiece of the 100 ° series is sealed and filled with an inert gas, argon. This process prevents the formation of condensation inside the eyepiece and prevents the entry of dust to maximize the lifetime of the internal coatings. To ensure watertightness, each eyepiece of the 100 ° series is factory tested by immersing it under water for 30 minutes to a depth of one meter.
All 100 ° eyepieces are fully multilayered and the edges are blackened to produce maximum contrast.
The Explore Scientific 100 ° delivers sharp, contrasting images. The apparent field of 100 ° is so wide, that you can keep in sight a celestial object observed in a non-motorized instrument.
The focal length of the Explore Scientific 100 ° eyepiece of 25 mm predestines it at low magnifications (40x on an optical tube of 1 meter of focal length), making it very suitable for the observation in detail of large nebulae or galaxies, clusters Galaxies or comets, while benefiting from a very wide field of vision.
The 25 mm eye relief is 14.5 mm: this means that the image remains comfortable up to 14.5 mm above the lens, in order to take full advantage of the field offered by the lens. ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
About Explore Scientific 100° 25mm - 2" [ES-EPWP10025-01]
  • Description    EXPLORE SCIENTIFIC 100° 25MM
  • Item Number    EPWP10025-01
  • Focal Length    25mm
  • Length    140mm
  • Width    73mm
  • Weight    41.5oz; 1177g
  • Barrel Size    2.00”
  • Eye Relief    14.5mm
  • Field Stop Diameter:    41mm
  • $52.00 CAD - [S1] USPS Ground Shipping (7-21 days)
    7 in × 7 in × 6 in
    4 lb
