Explore Scientific 82° Series 11mm - 1.25'' [ES-EPWP8211-01]
ES-EPWP8211-01
$227.52 CAD $299.37 CAD
Explore Scientific: Explore Scientific eyepiece, 11 mm focal length, 82 ° visible field, 31.75 mm (1.25 ").
In recent years, Explore Scientific eyepieces have gained a solid reputation in terms of quality, The eyepiece of Explore is a pleasant and easy experience, the image is beautiful from the first glance.
The focal length of the Explore Scientific 82 ° eyepiece of 11 mm predestines it at medium magnifications (91x on an optical tube of 1 meter of focal length). It is therefore very versatile, suitable for planetary observations (Moon, planets, Sun), double or multiple stars, as well as observation of planetary nebulae and the search for details in nebulae and galaxies.
The 11 mm eye relief is 15.6 mm: this means that the image remains comfortable up to 15.6 mm above the lens, to fully enjoy the field offered by the lens, ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25" ), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 82° Series 11mm - 1.25'' [ES-EPWP8211-01]
  • Description    11mm 82° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP8211-01
  • Focal Length    11mm
  • Length    87mm
  • Width    48mm
  • Weight    9.8oz; 279g
  • Barrel Size    1.25”
  • Eye Relief    15.6mm
  • Field Stop Diameter:    15.9mm
    5 in × 4 in × 4 in
    2 lb
