Explore Scientific 82° Series 4.7mm - 1.25'' [ES-EPWP8247-01]
ES-EPWP8247-01
$227.52 CAD $299.37 CAD
Explore Scientific: Scientific eyepiece, focal length 4.7 mm, apparent field 82 °, barrel size 31.75 mm (1.25 ").
The focal length of the Explore Scientific 82 ° 4.7 mm eyepiece is only suitable for observing small and bright objects (planets, planetary nebulae, globular clusters) since it delivers very high magnifications (212x on an optical tube of 1 Meter of focal length).
The eye relief of the 4.7 mm is 13.6 mm: this means that the image remains comfortable up to a distance of 13.6 mm above the lens, to fully enjoy the field offered by the lens, ocular. This is an important detail for the viewer wearing eyeglasses, which will keep them on the nose.
Finally, it fits into the 1.25 "(31.75 mm) eyepiece holders. The inside of the sink is threaded in M28.5 x 0.6 mm to accommodate filters with 31.75 mm (1.25" ), Such as interference filters of type OIII, UHC, H-Beta, etc., which serve to enhance the contrast on many nebulae.
About Explore Scientific 82° Series 4.7mm - 1.25'' [ES-EPWP8247-01]
  • Description    4.7mm 82° Series Argon-Purged Waterproof Eyepiece
  • Item Number    EPWP8247-01
  • Focal Length    4.7mm
  • Length    87mm
  • Width    43mm
  • Weight    7.5oz; 213g
  • Barrel Size    1.25”
  • Eye Relief    13.6mm
  • Field Stop Diameter:    6.9mm
    5 in × 4 in × 4 in
    2 lb
