Explore Scientific ED127mm Triplet Essential Series [ES-ED127075-03-CLEARANCE]
$1,567.47 CAD $3,134.94 CAD
Explore Scientific: Great for astrophotography, EXPLORE SCIENTIFIC ED127MM TRIPLET ESSENTIAL SERIES can capture in stunning detail many of the night sky’s most notable treasures.
With its true diffraction-limited optics and ample aperture, this versatile model can showcase deep sky delights like the edge-on Sombrero Galaxy with its distinct bulging center or the spiraling beauty of the face-on Pinwheel Galaxy as easily as it can reveal the intricacies of the Moon’s winding Hadley Rille.
Featuring an air-spaced triplet optical design that virtually eliminates chromatic aberrations, this telescope generates brilliant high-contrast images by combining genuine HOYA extra-low dispersion (ED) glass and proprietary EMD enhanced multi-layer coatings on all optical surfaces. As an added bonus, its quick set-up allows you to spend more time at the eyepiece to make the most of your nights under the stars.
About Explore Scientific ED127mm Triplet Essential Series [ES-ED127075-03-CLEARANCE]
  • Optical Design: Air-Spaced Triplet ED Apochromatic Refractor with HOYA® Dense Fluor Crown, FCD1 ED Glass
  • Clear Aperture: 127mm
  • Focal Length: 952mm
  • Focal Ratio: f/7.5
  • Resolving Power: .9 arc seconds
  • Coatings: EMD™ (Enhanced Multilayer Deposition) Coatings
  • Limiting Stellar Magnitude: 13
  • Maximum Practical Visual Power: 500x
  • Lowest Useful Visual Power: 14.5x Focuser: Ten-to-One Dual-Speed Crayford-Style, w/ Adjustable Tension and Lock
  • Cradle/Saddle Plate: Dual Ring Style – Fits Explore Scientific Mounts; Vixen Mounts; Meade LXD55/75 Mounts
  • Tube Diameter: 130mm
  • Tube Length: 41.75 in.; 1060mm (incl. dew shield) 33.25 in; 844mm (without dew shield)
  • Tube Construction: Aluminum; Stainless Steel Optical Tube Assembly
  • Weight (with all standard accessories): 22 lbs; 9.97 kgs.
    40.5 in × 11 in × 11 in
    26 lb
