G0-0300C color CCD camera with Sony ICX424AQ CCD [MVI-G0-0300C]
MVI-G0-0300C
$434.74 CAD $724.56 CAD
Moravian Instruments: 1/3'' progressive scan CCD 640 x 480 pixels, 1.25'' focuser adapter
About G0-0300C color CCD camera with Sony ICX424AQ CCD [MVI-G0-0300C]
Model CCD chip CCD architecture Color filters Resolution Pixel size Imaging area Download time
G0-0300 ICX424AL progressive none 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm ~ 0.05 s
G0-0300C ICX424AQ progressive RGBG (Bayer) 656 × 494 7.4 × 7.4 μm 4.9 × 3.7 mm ~ 0.05 s
G0-0800 ICX204AL progressive none 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm ~ 0.1 s
G0-0800C ICX204AK progressive RGBG (Bayer) 1032 × 778 4.65 × 4.65 μm 4.8 × 3.6 mm ~ 0.1 s
G0-2000 ICX274AK progressive none 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm ~ 0.25 s
G0-2000C ICX274AQ progressive RGBG (Bayer) 1628 × 1236 4.4 × 4.4 μm 7.2 × 5.4 mm ~ 0.25 s
