BackyardNIKON 2.1 Premium Edition [OTL-BYN-P]
OTL-BYN-P
$68.96 CAD
About BackyardNIKON 2.1 Premium Edition [OTL-BYN-P]
Supported Cameras
BackyardNIKON supports over 30 Nikon DSLR models!
When you see (serial) for a particular function, it means a serial cable is needed to access that function, in addition to the regular USB cable for all other functions. BackyardNIKON has been tested with Shoestring Astronomy DSUSB serial cables.
1V3 Yes Yes (usb) No W11 (32/64 bits) Yes
D3/D3S/D3X Not supported
D4 Yes Yes (usb) No W11 (32/64 bits) Yes
D4S Yes Yes (usb) No W11 (32/64 bits) Yes
D5 Yes Yes (usb) No W11 (32/64 bits) Yes
D40/D40X/D50/
D60/D70/D80
Not supported
D90 Yes Yes (serial) No W11 (32/64 bits) Yes
D200 No Yes (serial) No W11 (32 bits - Vista SP2 compatibility mode) Yes
D300 Yes Yes (serial) No W11 (32/64 bits) Yes
D300S Yes Yes (serial) No W11 (32/64 bits) Yes
D500 Yes Yes (usb) No W11 (32 bits) Yes
D600 Yes Yes (usb) No W11 (32/64 bits) Yes
D610 Yes Yes (usb) No W11 (32/64 bits) Yes
D700 Yes Yes (serial) No W11 (32 bits) Yes
D750 Yes Yes (usb) No W11 (32/64 bits) Yes
D780 Yes Yes (usb) No W11 (32/64 bits) Yes
D800 Yes Yes (usb) No W11 (32/64 bits) Yes
D810 Yes Yes (usb) No W11 (32/64 bits) Yes
D810a Yes Yes (usb) No W11 (32/64 bits) Yes
D850 Yes Yes (usb) No W11 (32 bits) Yes
D3000 Not supported
D3100 Not supported
D3200 Not supported
D3300 Not supported
D3400 Not supported
D3500 Not supported
D5000 Yes Yes (serial) No W11 (32/64 bits) Yes
D5100 Yes Yes (serial) No W11 (32/64 bits) Yes
D5200 Yes Yes (usb) No W11 (32/64 bits) Yes
D5300 Yes Yes (usb) No W11 (32/64 bits) Yes
D5500 Yes Yes (usb) No W11 (32/64 bits) Yes
D5600 Yes Yes (usb) No W11 (32/64 bits) Yes
D7000 Yes Yes (serial) No W11 (32/64 bits) Yes
D7100 Yes Yes (usb) No W11 (32/64 bits) Yes
D7200 Yes Yes (usb) No W11 (32/64 bits) Yes
D7500 Yes Yes (usb) No W11 (32/64 bits) Yes
Z5 Yes Yes (usb) n/a W11 (32/64 bits) Yes
Z6 Yes Yes (usb) n/a W11 (32/64 bits) Yes
Z6ii Yes Yes (usb) n/a W11 (32/64 bits) Yes
Z7 Yes Yes (usb) n/a W11 (32/64 bits) Yes
Z7ii Yes Yes (usb) n/a W11 (32/64 bits) Yes
Z8 Yes Yes (usb) n/a W11 (64 bits) Yes
Z50 Yes Yes (usb) n/a W11 (32/64 bits) Yes
Compare Editions
LIMITED WARRANTY
LIMITATIONS ON LIABILITY
GENERAL PROVISIONS
