AZ4000 HPS Cold version - Same as 10M4000AZ but with Extended operational temperature to -30°C (-22° F) [10M-4000AZF]
0 in stock specialorder
Altazimuth mount, professional grade,10Micron HPS technology with absolute axis-encoders and high performances motor drives; optional system to use two optical tubes (payload 150kg + 100kg) as shown on the pictures
This mount is based on the mechanics of the GM4000 HPS II and offers a very stable altazimuthal configuration: the AZ4000 HPS is a very versatile research mount, perfect for scientific activities such as satellite tracking, photometric and astrometric measurements, LiDaR laser applications and so on. Due to its altazimuthal design, this special mount isn’t suitable for astrophotography and for most of the amateur activities.
The standard version allows to assembly the optics to only a side of the mount and is supplied with a counterweight bar.
As option, is available the double telescope version which allows the use of two two or more optics in a side by side setup, optimizing the load of the Mount and taking advantage of the altazimuth configuration.
The Double telescope option i s compatible with all the plates used on the GM4000 series, including the dual plates Loduel and Maxidual; in this way is possible to use directly 4 optics, 2 per side.Designed to offer a great sturdiness with no flexures, is all made from machined aluminized alloy. You can order the AZ4000 HPS Mount already configured with the Double Telescope option, or buy it after as an accessory.
About AZ4000 HPS Cold version - Same as 10M4000AZ but with Extended operational temperature to -30°C (-22° F) [10M-4000AZF]
10Micron: AZ4000 HPS Cold version - Same as 10M4000AZ but with Extended operational temperature to -30°C (-22° F)
