AZ3000 HPS Cold version - Same as 10M3000AZ but with Extended operational temperature to -30°C (-22° F) [10M-3000AZF]
10M-3000AZF
$32,799.32 CAD
0 in stock specialorder
10Micron: AZ3000 HPS Cold version - Same as 10M3000AZ but with Extended operational temperature to -30°C (-22° F)
Altazimuthal mount, exclusive 10Micron HPS technology with absolute axis-encoders and high performances motor drives; payload capacity of 100 +55 Kg (220+ 143 lbs) in dual telescope configuration optional
The new AZ3000 HPS is an altazimuth mount based on the mechanics of the GM3000. The AZ3000 HPS is a very versatile research mount, perfect for scientific activities such as satellite tracking, photometric and astrometric measurements, LiDaR laser applications and so on. Due to its altazimuthal design, this special mount isn’t suitable for astrophotography and for most of the amateur activities.
The standard version allows to assembly the optics to only a side of the mount and is supplied with a short counterweight bar. It’s not necessary to exactly counterbalance the weight of the telescope: using counterweigths for about 50% of your payload to get a sufficient stable configuration.
An option is available for a dual telescope configuration, as shown on the pictures above (see options for further details).
About AZ3000 HPS Cold version - Same as 10M3000AZ but with Extended operational temperature to -30°C (-22° F) [10M-3000AZF]
