Astrozap Glass Solar Filter. 244mm-251mm. Clear aperture 203mm [AZ-1527]
About Astrozap Glass Solar Filter. 244mm-251mm. Clear aperture 203mm [AZ-1527]
Astrozap: ]Full Aperture Glass Solar Filter 244mm-251mm 9-5/8 to 9-7/8 diameter, fits Meade LXD-55 8 S/Newt, Meade 7” APO; Takahashi 212.
- SKU AZ-1527
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 8.1" - 11"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 10"
- FILTER FITS TELESCOPE OD RANGE OF... 244mm to 251mm
