Astrozap Glass Solar Filter. 213mm-219mm. Clear aperture 152mm [AZ-1523]
AZ-1523
$115.51 CAD $231.01 CAD
Astrozap: Full Aperture Glass Solar Filter 213mm-219mm 8-3/8 to 8-5/8 diameter, fits Celestron: Starhopper 6.
About Astrozap Glass Solar Filter. 213mm-219mm. Clear aperture 152mm [AZ-1523]
  • SKU    AZ-1523
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    8.1" - 11"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    8.75"
  • FILTER FITS TELESCOPE OD RANGE OF...    213mm to 219mm
