Panther mounting - Visual Packaging incl. Panther mounting head, arms, pier adapter, weight set and folding pier [TTS-160VP]
TTS-160VP
$9,687.76 CAD
0 in stock specialorder
Track the stars: Panther mounting - Visual Packaging incl. Panther mounting head, arms, pier adapter, weight set and folding pier
This package contains everything needed for a visual set-up:
Mount head with handpad
Top Mount with counterweight arms
2 x 4 kg Counterweights
Folding Pier
Pier Adapter
The visual package contains all the parts needed for a flexible mount system capable of balancing telescopes weighing up to 12-15 kg. For heavier telescopes you will need to add the 8 kg counterweights.
The package comes complete with transport bags and makes up a high quality transportable mount system. The visual package fits refractors up to 6 inch, SCT’s up to 11 inch and newtonians up to 10″.
Included Items
Mount Head Handpad Handpad cable PC connection cable Power cable with cigarette lighter connector Large transport bag for mount head Small transport bag for handpad Topmount, Arms Dovetail Saddle plate with counterweight arms 2 Magnetic handpad holders (installed on arms) 2 Brass bushings 2 M8x60 Stainless steel screws Counter Weights 2 x 4 kg Small transport bag Folding Pier Large Transport bag Pier Adapter
About Panther mounting - Visual Packaging incl. Panther mounting head, arms, pier adapter, weight set and folding pier [TTS-160VP]
Folding Pier
Pier Adapter
Included Items
  • Mount Head
  • Handpad
  • Handpad cable
  • PC connection cable
  • Power cable with cigarette lighter connector
  • Large transport bag for mount head
  • Small transport bag for handpad
  • Topmount, Arms
  • Dovetail Saddle plate with counterweight arms
  • 2 Magnetic handpad holders (installed on arms)
  • 2 Brass bushings
  • 2 M8x60 Stainless steel screws
  • Counter Weights 2 x 4 kg
  • Folding Pier
  • Large Transport bag
  • Pier Adapter
Additional information
MATERIALS
Stainless Steel and Aluminum, black hard anodized
AZIMUTH DRIVE
Ø100mm bronze worm gear drive combined with second stage friction roller gear. Springloaded worm assembly for zero backlash
ALTITUDE DRIVE
Ø120mm bronze worm gear drive. Springloaded worm assembly for zero backlash
DRIVE MOTORS
DC servomotors with high resolution encoders (0.14 arcsec step size)
POWER SUPPLY NEEDED
12V 3A battery
SLEWING SPEED
3 degrees per second
TELESCOPE CAPACITY
22 kg on Topmount / 2 * 15 kg on side mount dovetail saddles – depending on telescope length and weight distribution
OBJECT CATALOGS INSTALLED
Planets, Messier Catalog, NGC Catalog, IC catalog, Bright Star Catalog
PC INTERFACE
LX200/ASCOM Interface. Works with all major planetarium and telescope control software packages.
AUTOGUIDER PORT
ST4 Compatible port or Pulse guide via ASCOM
FIRMWARE
The internal firmware is stored inside the mount head and can be updated by the user via the PC interface.
SPECIFICATIONS
