Astrozap Glass Solar Filter. 181mm-187mm. Clear aperture 152mm [AZ-1520]
AZ-1520
$115.51 CAD $231.01 CAD
Astrozap: Full Aperture Glass Solar Filter 181mm-187mm 7-1/8 to 7-3/8 diameter, fits AstroPhysics 155; Celestron: NexStar 6/6SE, C6; Meade LXD 55 6 S/Newt; Orion: AstroView 6, SkyView Pro 6 & 6LT, SkyView Pro 3.6 CA, Skyview Deluxe 6 EQ, SkyQuest XT6; Vixen 150.
About Astrozap Glass Solar Filter. 181mm-187mm. Clear aperture 152mm [AZ-1520]
  • SKU    AZ-1520
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    6.1" - 8"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    7.50"
  • FILTER FITS TELESCOPE OD RANGE OF...    181mm to 187mm
