Astrozap Glass Solar Filter. 156mm-162mm. Clear aperture 127mm [AZ-1518]
AZ-1518
$108.60 CAD $217.19 CAD
Astrozap: Full Aperture Glass Solar Filter 156mm-162mm 6-1/8 to 6-3/8 diameter, fits Meade 127 NT; Orion: SpaceProbe 130ST, StarSeeker 130, 130 EDFS; AstroPhysics: 125, 130; Intes Micro MN56.
About Astrozap Glass Solar Filter. 156mm-162mm. Clear aperture 127mm [AZ-1518]
  • SKU    AZ-1518
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    6.1" - 8"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    6.50"
  • FILTER FITS TELESCOPE OD RANGE OF...    156mm to 162mm
