Astrozap Glass Solar Filter. 137mm-143mm. Clear aperture 127mm [AZ-1515]
About Astrozap Glass Solar Filter. 137mm-143mm. Clear aperture 127mm [AZ-1515]
Astrozap: Full Aperture Glass Solar 137mm-143mm 5-3/8 to 5-5/8 diameter, fits Celestron FirstScope 102; Meade: 4500, DS-127, 4”APO, DS2114, DS2130;Orion: AstroView 120 &120ST, SkyView Pro 120, StarBlast, StarMax 127, SkyView Pro 127, Apex 127;Sky-Watcher: Skymax 127;StellarVue: SV4, SV102T Takahashi: FS-102, 106 N, FSQ-106; Vixen 102Williams Optics ZS110 APO.
- SKU AZ-1515
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 4.1" - 6"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 5.75"
- FILTER FITS TELESCOPE OD RANGE OF... 137mm to 143mm
