Astrozap Glass Solar Filter. 117mm-124mm. Clear aperture 101mm [AZ-1513]
AZ-1513
$94.02 CAD $188.03 CAD
Astrozap: Full Aperture Glass Solar Filter 117mm-124mm 4-5/8 to 4-7/8 diameter, fits Celestron: FirstScope 76, NexStar 4/4SE, C4, 102HD; Meade: ETX 105, DSX 102, 2045; StellarVue: SV102EDSynta SkyWatcher 80 ED;Sky-Watcher: Evostar 80 EDQuestar 4.75”;Takahashi: FSQ-106 NUH/FSQ-106 ED Tele Vue: 101, 102;Vixen VMC110L.
About Astrozap Glass Solar Filter. 117mm-124mm. Clear aperture 101mm [AZ-1513]
  • SKU    AZ-1513
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    4.1" - 6"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    5"
  • FILTER FITS TELESCOPE OD RANGE OF...    117mm to 124mm
