Astrozap Glass Solar Filter. 51mm-57mm. Clear aperture 44mm [AZ-1503]
AZ-1503
$77.90 CAD $155.80 CAD
Astrozap: Full Aperture Glass Solar Filter 51mm-57mm (2 to 2-1/4) diameter, fits View finders, Cameras, Small Refractors, Spotting Scopes, and Binoculars; Celestron 9X50 finder.
About Astrozap Glass Solar Filter. 51mm-57mm. Clear aperture 44mm [AZ-1503]
  • SKU    AZ-1503
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    2" - 4"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    2"
  • FILTER FITS TELESCOPE OD RANGE OF...    51mm to 57mm
