Astrozap Glass Solar Filter. 48mm-54mm. Clear aperture 45mm [AZ-1502]
About Astrozap Glass Solar Filter. 48mm-54mm. Clear aperture 45mm [AZ-1502]
Astrozap: Full Aperture Glass Solar Filter 48mm-54mm 1-5/8 to 2-1/8 diameter, fits View Finders, Cameras, Small Refractors, Spotting Scopes, and Binoculars.
- SKU AZ-1502
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 2" - 4"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 1- 7/8"
- FILTER FITS TELESCOPE OD RANGE OF... 48mm to 54mm
