Pegasus Astro Pocket Powerbox Micro [PEG-PPBMICRO-CLEARANCE]
4 in stock On sale IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Pegasus Astro have equipped the PPB Micro with LED indication for power and failure states. The LED indicators can blink in patterns to warn of important power issues, such as over or under voltage. Though the light is already dim, it can be turned off using the software.
The PPB Micro comes with a watchdog that resets the device if there is no response from the controller for two seconds. This is a handy feature in the unlikely even of a controller freeze. The firmware is also upgradable to support future features and bug fixes.
Included Cables
Power Cables : Pegasus Astro has included four Dc 2.1 mm to 2.1 mm male power cables. Each are 1 meter in length.
External Environmental Sensor : Measuring 1 meter in length, the temperature and relative humidity sensor helps you know the exact environmental conditions of a user's location. The measurements are displayed in the software.
About Pegasus Astro Pocket Powerbox Micro [PEG-PPBMICRO-CLEARANCE]
Pegasus Astro: Pocket Powerbox (PPB)
Included Cables
PPB Micro Technical Specifications
- Supply Voltage: 12V - 13.8V DC
- Power Input Connector: DC 2.1 mm
- Connectivity: USB2 - Type B USB Connector
- 2 Channel x 12 PWM Output Max Current: 5A each
- 2 Channel x 12 PWM Output Max Connector: RCA
- Sensor Input Humidity Readings: 0-100% with 2-5% accuracy
- Sensor Input Temperature Readings: -40 to 80°C, ±0.5°C accuracy
- Camera / DSLR Output: Max 3Amps, 2.1mm center positive
- Voltmeter: Measures 5 - 15V
