Panther Folding Pier, including transport bag NOTE: Pier Adapter TTS160K is not included and must be ordered as a separate item. [TTS-160JA]
TTS-160JA
$1,628.87 CAD
0 in stock specialorder
Track the stars: Panther Folding Pier with adjustable feet, including transport bag
separate item.
NOTE: A mount head specific adapter plate is not included and must be
Extremely compact and easy to transport.
The Folding Pier comes in one single compact transport bag. It will fit in the trunk of even the smallest cars. When folded down the pier is completely smooth with no protruding parts and can be transported in the soft bag without any risk of damage to the Pier or surroundings. With a weight of only 11kg the Pier is easy to bring to the darkest places.
Fast setup and great stability
It takes only a few seconds to unfold the legs and mount the pier tube. The three support rods are easy to tighten and secures a very stable pier. With the Panther mount head there is no need for leveling the pier making the setup even faster.
Leveling
For use with other mount heads this version of the folding pier has adjustable feet for leveling the pier. The Feet can each be adjusted 15mm.
Pier extension
Sometimes for visual observations you might want a higher pier. This can easily be achieved by installing one or more Pier extensions.
Fast adapter for Mount Head
To attach the TTS-160 Mount head or another mount head to the folding pier you need a Pier adapter . This adapter attaches the mount head to the pier with a flick of  finger.
Using the Pier with other Mount Heads
The folding Pier can be adapted to be carry other mount heads. Installing the Pier adapter onto the mount head secures the same fast and easy assembly as with the TTS-160 Panther mount head.
About Panther Folding Pier, including transport bag NOTE: Pier Adapter TTS160K is not included and must be ordered as a separate item. [TTS-160JA]
separate item.
Leveling
Pier extension
11 kg
Materials
Stainless Steel and Aluminum, black hard anodized
Height
778 mm
Weight Capacity
80 kg
Transport Bag size
Diameter 180mm (7inch), Length 600mm (24 inch)
Specifications
