Panther Mini Pier [TTS-160F]
TTS-160F
$542.96 CAD
Track the stars:
Stable, compact, transportable
The Mini Pier makes the Panther mount an extremely transportable  mount system. The low height and short legs makes the pier just as stable as the bigger folding pier.
For astrophotography the minipier can be placed directly on the ground as there is no need to look through the telescope. This will give great stability and lower the influence from wind.
For visual use the minpier can be placed on a stable table or another stable flat surface.
Standard Pier adapter
The Mini Pier receives the standard Pier Adapter for fast and easy installation of the mount head.
It is also possible to install the Pier Extension between Mini Pier and Mount head.
About Panther Mini Pier [TTS-160F]
Track the stars:
3 kg
Materials
Stainless Steel and Aluminum, black hard anodized
Height
102mm
Weight Capacity
50kg
Transport Bag Size
Diameter 180mm (7inch), Length 300mm (12 inch)
Specifications
