Losmandy plate 495mm PLUS [PRI-PLLLOS495P]
PRI-PLLLOS495P
$134.16 CAD $163.61 CAD
0 in stock specialorder On sale
PrimaluceLab: The Losmandy style dovetail plate 495mm PLUS is designed to let you install your telescopes on mounts with this connection. This dovetail plate is 495mm long and is useful for installing large dimensions telescopes (such as Newton up to 300mm in diameter) on mounts with Losmandy plate (as the SkyWatcher AZ-EQ6, or EQ8).
Like all the elements of the PLUS system, this plate is made with high precision mechanics (built with CNC machines from aluminum block) and specially designed to enable you to easily install other mechanical components such as support rings, guide rings or dovetail clamps.
Thanks to the particular design, the Losmandy style dovetail plate 495mm PLUS can be:
positioned below the support rings to install the telescope on mounts with Losmandy plate installed above the support rings to increase the mechanical rigidity of the entire telescope (and allow you to attach other accessories such as guide rings to precisely adjust the position of the guide telescope). used as a basis to create a side-by-side plate (which allows you to install two telescopes in parallel on a mount with a single Losmandy plate) together with 2 dovetail clamps PLUS.  If you have other brands mechanical accessories, you can still use all the elements of the PLUS system. Indeed we have provided a series of central slots that allow, for example, to fix on this plate support or guide rings through a screw.
About Losmandy plate 495mm PLUS [PRI-PLLLOS495P]
  1. positioned below the support rings to install the telescope on mounts with Losmandy plate
  2. installed above the support rings to increase the mechanical rigidity of the entire telescope (and allow you to attach other accessories such as guide rings to precisely adjust the position of the guide telescope).
  3. used as a basis to create a side-by-side plate (which allows you to install two telescopes in parallel on a mount with a single Losmandy plate) together with 2 dovetail clamps PLUS.
