Vixen plate 90mm PLUS [PRI-PLLVIX90P]
5 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
Thanks to the particular design, the Vixen style dovetail plate 90mm PLUS can be:
positioned below the support rings to install the telescope on mounts with Vixen plate installed below a camera to connect it to a mount with Vixen dovetail clamp installed below a telescope or a camera to connect it to a photographic head with Arca Swiss dovetail clamp installed above the support rings to increase the mechanical rigidity of the entire telescope (and allow you to attach other accessories such as guide rings to precisely adjust the position of the guide telescope). Vixen style dovetail plate 90mm PLUS installed below a camera: this way you can connect the camera on a photographic head (to the left) or to a mount (to the right) in the same way of a telescope.
About Vixen plate 90mm PLUS [PRI-PLLVIX90P]
PrimaluceLab:The Vixen style dovetail plate 90mm PLUS is designed to let you install telescopes or cameras on mounts with Vixen type clamp or photographic heads with Arca Swiss type clamp. This Vixen style dovetail plate is 90mm long and, not only it comes with central threaded holed and slots, but also threaded holes to connect to other PLUS mechanical components such as support rings, guide rings, dovetail clamps or EAGLE computers always with more crews, in order to avoid any flexure! Like all the elements of the PLUS system, this plate is made with high precision mechanics, it's built with CNC machines from aluminum block) and anodized to increase the hardness of the material and protect it from oxidation.
- positioned below the support rings to install the telescope on mounts with Vixen plate
- installed below a camera to connect it to a mount with Vixen dovetail clamp
- installed below a telescope or a camera to connect it to a photographic head with Arca Swiss dovetail clamp
- installed above the support rings to increase the mechanical rigidity of the entire telescope (and allow you to attach other accessories such as guide rings to precisely adjust the position of the guide telescope).
