Pegasus Astro DewZap - Dual Channel Dew Heater Controller [PEG-DEWZAP]
PEG-DEWZAP
$76.70 CAD $153.40 CAD
Pegasus Astro: DewZap - Dual Channel Dew Heater Controller
DewZap is our Dual Channel Dew Heater Controller. Simple to use, powerful and very compact is your best companion against the dew during long astro – nights.
Two individual digital outputs for dew heating systems.
DewZap has two individual digital RCA outputs. You can control its output by turning each knob on the top of the controller.
Pulse Width Modulation Duty Cycle Control
Controller was built with modern digital electronics and fully supports duty cycle (PWM) control.
Reverse polarity protected.
Device is protected from reverse polarity.
LED Operation indicator
A led indicator in front of the faceplate ensures controller is operational.
Detachable fused power cord
A detachable 1.8m fused power cord (1.8m length) is provided. The fuse is at 8 Amps.
Zero to 100% heater control
Knobs can drive Pulse Width Modulation duty cycle from zero to 100%
Ten (10) amps current capacity (5 amps per channel)
Powerful mosfets on each output can provide easily 5Amps per channel. There are no voltage drops there.
In the box:
DewZap Controller
Cigarette Lighter Power Cord (1.8m length)  – 8A slow fused
2 Years warranty
Covers the controller device
About Pegasus Astro DewZap - Dual Channel Dew Heater Controller [PEG-DEWZAP]
In the box:
DewZap Controller
2 Years warranty
Supply Voltage 12V DC Operation
Output Same input voltage in Pulse Width Modulation Duty Cycle
Channels Dual (2)
Power Outlets 2 x RCA
Power Input Connector 2.1mm Centre Positive Socket
Dimensions 66 mm x 66 mm x 28 mm
Detachable fused power cord  A Slow fuse is at 8Amps, located on tip. Cord has 1.8m length
