SESTO SENSO 1 33mm adapter [PRI-SESTOSENSO-AD33]
About SESTO SENSO 1 33mm adapter [PRI-SESTOSENSO-AD33]
PrimaluceLab: This 33mm adapter allow you to install SESTO SENSO 1 on focusers that come with 33mm diameter large shaft, like the 2,5" and 3" FeatherTouch (or other focusers with 33mm diameter large shaft). SESTO SENSO as standard connects to focusers that comes with 25mm diameter shaft (that are the most of the focusers on the market): in order to connect it to focusers that comes with 33mm diameter large shaft, you need to add this adapter.
