Eagle-compatible power cable for SkyWatcher AZ-EQ6 and AZ-EQ5 mounts - 115cm 3A [PRI-PL1000026]
PRI-PL1000026
$38.26 CAD $76.52 CAD
3 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
PrimaluceLab: The Eagle control unit can directly power supply SkyWatcher mounts. We build appropriate 12V power supply cables with various lengths. The Eagle-compatible power cables have on a side the jack (for 12V power supply) of the instrument they are designed for. On the other side they have the 3A plug with screw to prevent being disconnected accidentally from the Eagle.
If the cable for your equipment is not present among the optional accessories, please contact us and we will build for you.
About Eagle-compatible power cable for SkyWatcher AZ-EQ6 and AZ-EQ5 mounts - 115cm 3A [PRI-PL1000026]
