0,5m Eagle power cable extension cord [PRI-PL10000AND]
4 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
About 0,5m Eagle power cable extension cord [PRI-PL10000AND]
PrimaluceLab: In order to power the Eagle (which in turn can power all other connected devices) you can use a battery or an A/C power supply. If you already have a battery of sufficient capacity, you can connect to Eagle with this 12V power cord. On the one side it has the Eagle screw connector, on the other one it has an Anderson connector with 16A fuse to avoid polarity inversion
