Eagle-compatible power cable with 5.5 - 2.5 connector - 115cm for 8A port [PRI-PL1000045]
PRI-PL1000045
$33.63 CAD $67.25 CAD
17 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
PrimaluceLab: This Eagle-compatible power cable allows you to power devices that comes with 5.5 (outer diameter) - 2.5 (inner diameter), positive tip polarity. This cable connects to the 8A port of the EAGLE, with screw connector to avoid unwanted detachment. The cable is 115cm long.
By using this cable, you can power these devices through EAGLE:
Moravian cooled cameras
About Eagle-compatible power cable with 5.5 - 2.5 connector - 115cm for 8A port [PRI-PL1000045]
  • Moravian cooled cameras
