Counterweight 20 kg GM4000 [10M-4083]
10M-4083
$604.61 CAD
0 in stock specialorder
10Micron: Stainless steel 20Kg counterweight for GM4000 mounts.
This 20 KG counterweight is exclusively designed  for GM4000 mounts; a precise 60mm hole offers a smooth movement on the shaft and facilitates the balancing operations; the stainless steel guarantees no corrosion. For the best safe tightening, the counterweight is provided with a not protruding set screw. Our technical department will suggest the correct number of counterweights based on your optical payload.
About Counterweight 20 kg GM4000 [10M-4083]
