Standard round Steel pillar for GM4000 [10M-4230]
0 in stock specialorder
The Standard round pillar is designed for a fixed base installation of the GM4000 mounts. The standard height is 120 cm (47.2”) but different customized heights are available on request. The base features a single, circular shape plate without adjustments. The #10M-4090 Pier Adapter flange is required to fit the mount (the #10M-4090 is already supplied with the #10M-4199 GM 4000 Mandatory shipping KIT)
About Standard round Steel pillar for GM4000 [10M-4230]
10Micron: Standard round Steel pillar for GM4000, by 10Micron (with single round base plates - tube diam. 250mm - H. 120 cm)
