Lateral Double 4" Plate "Maxidual XL" with 2pc #10M2185, mounted on a 4" Dovetail bar 400 mm long, including a Maxi clamping plate #10M2135 [10M-2100XL]
0 in stock specialorder
This special double plate is designed to allow a parallel mounting of two optical tubes on the 10Micron mounts. The bottom slide is a 4” dovetail bar 400mm length, with special threaded holes; the clamping plates are two XL 3” Losmandy compatible (#10M-2185), length 350mm.
All the components are CNC machined, black anodized aluminum. They are 3 different possible distances between the two clamps: appr. 210, 245 and 281mm (8.3”, 9.6”, 11”) ;included in the set is a Maxi clamping plate #10M-2135 which fits directly on the GM2000 mounts and via the following adapters on the GM3000 and GM4000 mounts:
#10M-3545 | Flange adapter for clamping plates (GM3000)
#10M-4545 | Flange adapter for clamping plates (GM4000)
Included items:
Material: Black anodized, CNC machined aluminum Bottom dovetail 4”, 400mm length, with special threaded holes Two 3” clamps XL #10M2185, Losmandy compatible, length 200mm Center to center distance : adjustable, appr. 210, 245 and 281mm (8.3”, 9.6”, 11”) Weight: appr. 6Kg (13.2 lbs) Included a Maxi clamping plate #10M2135, compatible with GM2000/3000/4000 mounts
About Lateral Double 4" Plate "Maxidual XL" with 2pc #10M2185, mounted on a 4" Dovetail bar 400 mm long, including a Maxi clamping plate #10M2135 [10M-2100XL]
10Micron: Lateral Double 4" Plate "Maxidual XL" with 2pc #10M-2185, mounted on a 4" Dovetail bar 400 mm long, including a Maxi clamping plate #10M-2135
Included items:
- Material: Black anodized, CNC machined aluminum
- Bottom dovetail 4”, 400mm length, with special threaded holes
- Two 3” clamps XL #10M2185, Losmandy compatible, length 200mm
- Center to center distance : adjustable, appr. 210, 245 and 281mm (8.3”, 9.6”, 11”)
- Weight: appr. 6Kg (13.2 lbs)
- Included a Maxi clamping plate #10M2135, compatible with GM2000/3000/4000 mounts
