Lateral Double 4" Plate "Maxidual" with 2pc #10M2085, mounted on a 4" Dovetail bar 400mm long, incuding a Maxi clamping plate #10M2135 [10M-2100]
0 in stock specialorder
This special double plate is designed to allow a parallel mounting of two optical tubes on the 10Micron mounts. The bottom slide is a 4” dovetail bar 400mm length #10M-2199, with special threaded holes; the clamping plates are two 3” Losmandy compatible (#10M-2085), length 200mm. All the components are CNC machined, black anodized aluminum.
They are 3 different possible distances between the two clamps: appr. 210, 245 and 281mm (8.3”, 9.6”, 11”) ; included in the set is a Maxi clamping plate #10M-2135 which fits directly on the GM2000 mounts and via the following adapters on the GM3000 and GM4000 mounts:
#10M-3545 | Flange adapter for clamping plates (GM3000)
#10M-4545 | Flange adapter for clamping plates (GM4000)
Included Items:
Base bar 4” dovetail, 400mm lenght Nr.2 clamps #10M2085, 3” Losmandy compatible (all the components are pre-assembled and aligned) Nr.1 Maxi clamping plate #10M2135
About Lateral Double 4" Plate "Maxidual" with 2pc #10M2085, mounted on a 4" Dovetail bar 400mm long, incuding a Maxi clamping plate #10M2135 [10M-2100]
10Micron: Lateral mounting plate Double 4" "Maxidual" , including two 3" clamps #10M-2085, for parallel mounting of two optical tubes.
Included Items:
- Base bar 4” dovetail, 400mm lenght
- Nr.2 clamps #10M2085, 3” Losmandy compatible (all the components are pre-assembled and aligned)
- Nr.1 Maxi clamping plate #10M2135
