CENTAURUS II Tripod designed for the GM2000 mounts [10M-2057]
0 in stock specialorder
Thanks to the ABSOLUTE HPS-ENCODERS, now we also can measure that a variation in length of 1/10 of a millimeter (0.0042) in one tripod leg directly equals up to 10 arc-second displacement of the object observed. This also holds true in case one tripod leg is sinking into the ground just by this small amount during an imaging session. With these encoders you can see what had been not measurable before – and it makes all aspects of an improper telescope set up show up mercilessly. For this reason the legs of the new tripods are made of ultra hard aircraft aluminum, fastened with way oversized spread-clamps and each tripod tip is equipped with a tiltable, hard, zero play contact plate. The Centaurus II tripod is optimized to the utmost, to bring the ABSOLUTE 10Micron HPS-accuracy straight into the ground – without compromise. Any chain is just as strong as its weakest link. When using an CENTAURUS II tripod, your 10Micron HPS-mount chain stays rock solid.
A special adapter (#10M1091) allows to fit the also the GM1000 mount for an extra sturdy configuration.
Included items:
Centaurus II tripod Triangle shaped accessory tray Control box holder Cordura carrying bag Ready to use with GM2000 mounts
About CENTAURUS II Tripod designed for the GM2000 mounts [10M-2057]
10Micron: The CENTAURUS II was designed specifically to support the mobile HPS-encoder technology exclusively found in portable 10Micron GM2000 mounts. This tripod offers the very best ratio of load capacity versus portable weight and is absolutely safe against leg sink. Only now, after the 10Micron HPS-technology has found such widespread recognition, it becomes obvious how extremely important it is to not destroy the ultimate guiding accuracy provided by 12 million code increments (equivalent to a resolution of 0.15 arc seconds) for each mount-axis just by using inappropriate equipment, like a not suitable tripod, the mirror-flop (or lens flop..) of the telescope optics, thin or poor optical tubes of many commercial telescopes, wobbly economy-focusers, as well as light connections between main- and guide-telescope. Any source of flex appears like being “magnified” 20-fold – while the resolution does improve by the same degree.
Included items:
- Centaurus II tripod
- Triangle shaped accessory tray
- Control box holder
- Cordura carrying bag
- Ready to use with GM2000 mounts
