Eyepiece Filter Blue 2", 470nm Bandpass, Optically Polished w/MC [BA-FCFB-2]
BA-FCFB-2
$89.87 CAD $119.83 CAD
Baader: Eyepiece Filter Blue 2", 470nm Bandpass, Optically Polished w/MC
This high-quality 2" filter from Baader is comparable to the Wratten #80A Filter in color. It is a bandpass filter with high transmission at 470nm.
More About Baader Color Filters
Baader Color Filters offer maximum brightness. No reflections, ghosting or stray light. Each filter is fine-optically, plane parallel polished to within 30 seconds of arc! Professionally coated with 7 layers of MC coatings that result in an image free of false reflections. The high quality glass in Baader color filters is only 2 mm thick for easy insertion anywhere in the optical path. Stackable filter cells have both male and female threads, allowing you combine filters to suit your needs. Baader - Not just another colored filter. Baader Premium Colored Filters bring a new level of quality and performance to planetary contrast enhancement.
About Eyepiece Filter Blue 2", 470nm Bandpass, Optically Polished w/MC [BA-FCFB-2]
  • This high-quality 2" filter from Baader is comparable to the Wratten #80A Filter in color. It is a bandpass filter with high transmission at 470nm.
  • Baader Color Filters offer maximum brightness. No reflections, ghosting or stray light.
  • Each filter is fine-optically, plane parallel polished to within 30 seconds of arc!
  • Professionally coated with 7 layers of MC coatings that result in an image free of false reflections.
  • The high quality glass in Baader color filters is only 2 mm thick for easy insertion anywhere in the optical path.
  • Stackable filter cells have both male and female threads, allowing you combine filters to suit your needs.
  • Baader - Not just another colored filter. Baader Premium Colored Filters bring a new level of quality and performance to planetary contrast enhancement.
  • Model Number    FCFB-2
  • Filter - Single or Set?    Single Filter
  • Filter Size    50.8 mm (2")
  • Filter Type    Planetary Color
  • Filter Shape    Round
  • Mounted or Unmounted?    Mounted
  • Wratten Number or Equivalent    #38A Blue
  • Filter Warranty    One Year
