Eyepiece Filter Dark Blue 1.25", 435nm Bandpass, Optically Polished w/MC [BA-FCFDB-1]
This high-quality filter from Baader is comparable to the Wratten #38A Filter in color. It is a bandpass filter with high transmission at 435nm.
More About Baader Color Filters
Baader Color Filters offer maximum brightness. No reflections, ghosting or stray light. Each filter is fine-optically, plane parallel polished to within 30 seconds of arc! Professionally coated with 7 layers of MC coatings that result in an image free of false reflections. The high quality glass in Baader color filters is only 2 mm thick for easy insertion anywhere in the optical path. Stackable filter cells have both male and female threads, allowing you combine filters to suit your needs.
About Eyepiece Filter Dark Blue 1.25", 435nm Bandpass, Optically Polished w/MC [BA-FCFDB-1]
Baader: Eyepiece Filter Dark Blue 1.25", 435nm Bandpass, Optically Polished w/MC
- Baader Color Filters offer maximum brightness. No reflections, ghosting or stray light.
- Each filter is fine-optically, plane parallel polished to within 30 seconds of arc!
- Professionally coated with 7 layers of MC coatings that result in an image free of false reflections.
- The high quality glass in Baader color filters is only 2 mm thick for easy insertion anywhere in the optical path.
- Stackable filter cells have both male and female threads, allowing you combine filters to suit your needs.
- Model Number FCFDB-1
- Filter - Single or Set? Single Filter
- Filter Size 31.75 mm (1.25")
- Filter Type Planetary Color
- Filter Shape Round
- Mounted or Unmounted? Mounted
- Wratten Number or Equivalent #38A Blue
- Filter Warranty One Year
