Stainless steel tip set (3 pcs) for T-POD 90/110/130 tripods. [AV-9TPS001]
AV-9TPS001
$22.29 CAD $44.58 CAD
5 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
Avalon Instruments: Stainless steel tip set (3 pcs) for T-POD 90/110/130 tripods.
Set of 3 Avalon stainless steel tips for tripod T-POD 90/110/130. These three points are screwed at the end of each foot to be able to firmly insert the tripod into the earth. Compatible with all Avalon tripods.
For an optimal stability of the tripod, these three points complete the whole by screwing at the end of each foot. You can then firmly press the tripod into the ground.
They are compatible with all Avalon tripods (T-90, T-110 and T-130).
About Stainless steel tip set (3 pcs) for T-POD 90/110/130 tripods. [AV-9TPS001]
