75 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R75]
ADM-R75
$91.83 CAD $122.44 CAD
ADM Accessories: Pair of 75 mm finderscope rings with 3/8" aluminum screws with large 1/4" Delrin Tips for adjusting. Thoroughly made of stainless steel and anodized aluminum for maximum longevity. An ideal way to mount a guidescope to large Dobsonian rocker boxes or existing optical tube rings. Each ring features three 1/4x20 TPI holes. Center hole is fixed to a 1.25" flat base while the other two holes are each 1/2" from the center and 1" apart from each other. Includes two 75mm (ID) adjustable guidescope rings with large delrin tipped thumb screws. Adjustable from 40mm – 70mm. Wt. as shown 8 oz.
About 75 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R75]
Weight .6 lbs
Dimensions 6 x 4 x 4 in
    6 in × 4 in × 4 in
    0.6 lb
