90 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R90]
ADM-R90
$98.16 CAD $130.88 CAD
ADM Accessories: Pair of 90 mm finderscope rings with 3/8" aluminum screws with large 1/4" Delrin Tips for adjusting. Thoroughly made of stainless steel and anodized aluminum for maximum longevity. An ideal way to mount a guidescope to large Dobsonian rocker boxes or existing optical tube rings. Each ring features three 1/4x20 TPI holes. Center hole is fixed to a 1.25" flat base while the other two holes are each 1/2" from the center and 1" apart from each other.
Fits V Series dovetail bars. Includes two 90mm (ID) adjustable guidescope rings with large delrin tipped thumb screws. Adjustable from 60mm – 80mm. Wt. as shown 10 oz.
About 90 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R90]
Weight .8 lbs
Dimensions 6 x 4 x 2 in
    6 in × 4 in × 2 in
    0.8 lb
