HERCULES, Wood tripod [GPK-30H100]
GPK-30H100
$807.89 CAD $1,077.18 CAD
0 in stock specialorder On sale
GEOPTIK: This tripod has a connection for mounts GK300, EQ6, Atlas, and adapters also GM8 Losmandy mounts, G11 (# 30H150) and HEQ5 (# 30A230)
The base is finely CNC machined and anodized.
The beech wood is used "first choice" and treated for outdoor use. We chose this material because of its excellent stability and vibration damping; also not afraid of heavy loads.
The height of the tripod can range from 950 mm to 1100 mm through terminal aluminum.
This extension is reversible, offering the possibility of a rubber tip or metal. The triangle, laminated beech, has 5 holes for eyepieces 31.8 and 3 holes for eyepieces 50.8. It also has a machining "container" to hold small parts (screws, filters, etc.)
Other holes in the legs allow you to store three ocular Extra equipment by 31.8 and 50.8 mm.
Tightening the legs to the plate through the "screws recovery" that allow a perfectly secure and stable extraordinary.
Max load 150 Kg
About HERCULES, Wood tripod [GPK-30H100]
Max load 150 Kg
