M-ZERO DUAL DEC ADAPTER [AV-9ADD001]
The M-zero mount several configurations (operating mode – telescope type) are summarized with accessories: Dual Dec Adapter, Gp Clamp and GP bar 23mm h.
- Two parallel telescopes: 106 mm f/5 refractor weighting about 9 kg and a 60 mm secondary refractor weighting about 3 kg.
In this setup a suitable length secondary tube is mounted on the optional tool. It can be used for autoguiding, for taking simultaneous picture with different FOVs or different filter, etc. In this case the second telescope constitutes an active counterweight allowing the mount to obtain performances that should require much higher loading capacity mounts. Counterweights used 2 kg total.
- Two parallel tubes: 8” f/10 SC weighting about 7 kg and 70 mm secondary refractor weighting about 3 kg:
In this setup the secondary tube is mounted on the optional X-Guider allowing a precise alignment between the two optics.
- with DSLR Camera
installed on the M-zero mount, allowing to perform wide and extra wide field expositions. It can be mounted standalone or in parallel with a telescope. In this case the telescope can be used as guide scope for longer expositions. With this setup a counterweight is not necessary
About M-ZERO DUAL DEC ADAPTER [AV-9ADD001]
Avalon Instruments: Dual Dec Adapter to use with: AVMZALWO (Dec clamp), AVMZALWX (DSLR adapter Bar) with direct attachmente for X- Guider.
- with DSLR Camera
