Optolong UV-IR Cut 1.25'' Filter [OPTO-UV-IR-125]
OPTO-UV-IR-125
$33.68 CAD $74.84 CAD
Optolong: UV-IR cut filter is designed for ultraviolet and infrared wavelength blocking to improve sharpness of the image as most of the optics are designed for the visible spectrum, because it’s very difficult to create a lens with the same focal point for the visible and IR spectrum.It is used on a digital camera and the video, which do not have an IR protection filter toward an image sensor or were remodeled. This is important because unfiltered CCD and CMOS sensors are extremely susceptible to UV and IR rays just outside the visible spectrum that can have a very negative impact on image quality.
About Optolong UV-IR Cut 1.25'' Filter [OPTO-UV-IR-125]
  • Glass quality Schott glass
  • Thickness 2mm
  • Surface quality 60/40 standard MIL-O-13830
  • 95% transmission from 420nm to 680nm
