ATIK ELECTRONIC FILTER WHEEL - 50MM ROUND FILTERS - 5 POSITIONS [ATK-0088]
ATK-0088
$580.62 USD
Atik Cameras: Atik 50 mm Electronic Filter Wheel
This product is the Atik 5-Position 50 mm Filter size Electronic Filter Wheel.
This new Filter Wheel employs exchangeable filter disks, allowing for multiple combinations, and has large 54 mm openings on both sides. With these features, the EFW2 can easily support sensors up to full frame (35 mm) format. The EFW2 also features a slick design, with a slim and lightweight profile. For example, the distance between any Atik camera and the wheel itself is 0 mm, while still maintaining the possibility of rotating the camera to any desired position. Total extra backfocus needed will be only 22 mm.
For the Atik Electronic Filter Wheel product line, the filter disk size options include 5 x 50.8 mm, 5 x 2" mounted, 7 x 36 mm, and 9 x 1.25" mounted.
As for sofware, the EFW2 has an ASCOM compliant driver, so that ANT compliant software can control it. Additionally, the EFW2 can be controlled by Atik's Artemis Capture software, for easy, simple, efficient operation.
Included With The Atik Electronic Filter Wheel (EFW2) In The Box:
Filter Wheel: EFW2 body with your choice of filter disk 2" adapter Hex key kit Screws, plastic washers, and o-rings (with specific disk options) Control Cable: 3-meter long USB cable Power: 1.8-meter long battery power connector Interface: Mini USB type Power: 12 VDC, 0.3 A (max) Weight: approx. 500 gr CD-ROM with drivers, software, and User's Manual (PDF) Quickstart Guide (paper)
About ATIK ELECTRONIC FILTER WHEEL - 50MM ROUND FILTERS - 5 POSITIONS [ATK-0088]
  • Filter Wheel: EFW2 body with your choice of filter disk
  • 2" adapter
  • Hex key kit
  • Screws, plastic washers, and o-rings (with specific disk options)
  • Control Cable: 3-meter long USB cable
  • Power: 1.8-meter long battery power connector
  • Interface: Mini USB type
  • Power: 12 VDC, 0.3 A (max)
  • Weight: approx. 500 gr
  • CD-ROM with drivers, software, and User's Manual (PDF)
  • Quickstart Guide (paper)
  • Connection: Mini USB 2.0
  • Weight: 500 g
  • USB cable: Length 3 m
  • Battery adapter cable: Length 1.8 m
  • CD Rom: Driver software, Drivers, Operating instructions in PDF
  • Power supply: 12V DC 0.3A
  • Pentium III 128MB RAM - Windows XP / Vista / Win7 / Win8 - CD-ROM drive and USB 2.0 port
  • Model: Atik EFW2 filter wheel - 5 positions 50 mm not mounted
  • Supplied tools: Specific keys and screws
  • BackFocus: 22 mm
  • Filter diameter: 50.8 mm or 2 "
  • Number of possible filters: 5
