Atik Electronic Filter wheel - for 9x 1.25'' filters [ATK-0085]
ATK-0085
$597.24 USD
Atik Cameras: High quality filter wheel with 54mm free aperture - suitable for full size sensors. Atik is pleased to introduce a new motorized filter wheel, with multiple filter capability. This new wheel employs exchangeable filter disks, allowing for multiple combinations, and has large 54mm openings on both sides.
With these features, the EFW2 can easily support sensors up to full frame (35mm) format. The EFW2 also features a slick design, with a slim and lightweight profile. For example, the distance between any Atik camera and the wheel itself is 0mm, while still maintaining the possibility to rotating the camera to any desired position. Total extra backfocus needed will be only 22mm.
Of special interest to Atik 383L+ users is the short distance from the filters to the CCD. This means that popular 1.25″ filters can be used with this sensor down to f/5, without any relevant vignetting. Filter disk options include 5×50.8mm, 5×2” mounted, 7x36mm and 9×1.25” mounted (1,25″ version on this page). On the sofware side, the EFW2 has an ASCOM compliant driver, so that any compliant software can control it. Additionally, the EFW2 can be controlled our Artemis Capture software, for easy, simple and efficient operation.
What’s included in the box?
EFW2 body with 1,25″ filter disk 2″ adapter Hex key kit Screws, plastic washers and o-rings (with specific disk options) 3-metre USB cable 1.8-metre battery power connector CD-ROM with drivers, software and user’s manual (PDF) Quickstart guide (paper). A universal (110-230V) power adapter is optional. System requirements: Pentium III PC with 128MB RAM, XP/Vista/Win7, CD-ROM drive and USB 2.0 port.
About Atik Electronic Filter wheel - for 9x 1.25'' filters [ATK-0085]
  • EFW2 body with 1,25″ filter disk
  • 2″ adapter Hex key kit Screws,
  • plastic washers and o-rings (with specific disk options)
  • 3-metre USB cable
  • 1.8-metre battery power connector
  • CD-ROM with drivers,
  • software and user’s manual (PDF)
  • Quickstart guide (paper).
  • Connexion: Mini USB 2.0
  • Poids: 500 g
  • Câble USB: Longueur 3 m
  • Câble d'adaptation batterie: Longueur 1,8 m
  • CD Rom: Logiciel de pilotage, Pilotes, Mode d'emploi en PDF
  • Alimentation: 12V DC 0,3A
  • Recette Informatique: Pentium III 128Mo de RAM - Windows XP / Vista / Win7 / Win8 - Lecteur CD-ROM et port USB 2.0
  • Modèle: Roue à filtres Atik EFW2 - 9 positions 31,75 mm
  • Outils fournis: Clés spécifiques et visserie
  • BackFocus: 22 mm
  • Diamètre des filtres: 31,75 mm soit 1,25 "
  • Nombre de filtres possibles: 9
