Atik 4120EX Color [ATK-0139]
Features of the 4-Series
The slim, ergonomic design of these cameras naturally comes in at a low weight to help minimize stress on the corrector plate. The desiccant port is readily accessible from outside the camera for easy maintenance , and a simple 12V power requirement is complimented by low power use to help you get the most out of your imaging sessions, whether in the observatory or out in the field.
EXview
What's in the box?
3-metre USB cable
Quickstart guide (paper)
About Atik 4120EX Color [ATK-0139]
Atik Cameras: The 12 megapixel sensor of the Atik 4120EX is the ideal solution for capturing stunning high resolution images. Exclusively available as one-shot colour (OSC), this is an ideal match for Hyperstar systems and short focal length telescopes. The small 3,1 µm pixels are able to faithfully record the colour of stars and nebulae, even in the fastest imaging systems. The high resolution means you can print your images to A3 and beyond, while the famed sensitivity of the Sony EXview sensor ensures those images are brimming with detail.
EXview
What's in the box?
3-metre USB cable
- Sensor Type: CCD - Sony ICX834AQG
- Horizontal Resolution: 4241 pixels
- Vertical Resolution: 2829 pixels
- Pixel Size: 3.1 µm x 3.1 µm
- ADC: 16 bit
- Readout Noise: 5e- typical value
- Gain Factor: 0.14e-/ ADU
- Full Well: ~9,000 e-
- Dark Current: ~0.0003 electrons/second at -10°
- Interface: Mini-USB 2.0 High Speed
- Power: 12v DC 1A
- Maximum Exposure Length: Unlimited
- Minimum Exposure Length: 1/1000 s
- Cooling: Thermoelectric set point with max ΔT=-25°C
- Weight: approx. 400 gr
- Back focus: 13mm ±0.5
- Exclusively available as one-shot colour
System Requirements
- Pentium III PC with 128MB RAM
- CD-ROM drive
- USB 2.0 port
