Atik 490EX Mono [ATK-0110]
This opens up the possibility of working at longer focal lengths and boosting the already impressive sensitivity to capture even the faintest color data.
Features of the 4-Series
The slim, ergonomic design of these cameras naturally comes in at a low weight to help minimize stress on the corrector plate. The desiccant port is readily accessible from outside the camera for easy maintenance , and a simple 12V power requirement is complimented by low power use to help you get the most out of your imaging sessions, whether in the observatory or out in the field.
EXview
What's in the box?
3-metre USB cable
Quickstart guide (paper)
About Atik 490EX Mono [ATK-0110]
Atik Cameras: The Atik 490EX combines high resolution imaging with the incredible sensitivity of the Sony ICX814 sensor and versatility of the 4-Series design. The small 3,69 µm pixels are ideally matched with short-mid focal length telescopes for images rich in detail, while also displaying high performance at multiple binning levels.
EXview
What's in the box?
3-metre USB cable
- Sensor Type: CCD - Sony ICX814 /5
- Horizontal Resolution: 3379 pixels
- Vertical Resolution: 2703 pixels
- Pixel Size: 3.69 µm x 3.69 µm
- ADC: 16 bit
- Readout Noise: 5e- typical value
- Gain Factor: 0.19e-/ ADU
- Full Well: ~12,500e-
- Dark Current: ~0.0003 electrons/ second at -10°
- Interface: Mini-USB 2.0 High Speed
- Power: 12v DC 1A
- Maximum Exposure Length: Unlimited
- Minimum Exposure Length: 1/1000 s
- Cooling: Termoelectric set point with max ΔT=-25°C
- Weight: approx. 400 gr
- Backfocus: 13mm ±0.5
- Available as mono or colour
System Requirements
- Pentium III PC with 128MB RAM
- CD-ROM drive
- USB 2.0 port
