Atik 460EX Mono [ATK-0100]
Features of the 4-Series
The slim, ergonomic design of these cameras naturally comes in at a low weight to help minimize stress on the corrector plate. The desiccant port is readily accessible from outside the camera for easy maintenance , and a simple 12V power requirement is complimented by low power use to help you get the most out of your imaging sessions, whether in the observatory or out in the field.
EXview
What's in the box?
3-metre USB cable
Quickstart guide (paper)
About Atik 460EX Mono [ATK-0100]
Atik Cameras: The 460EX is a flagship of the Atik camera range, renowned for its perfect balance of sensitivity and resolution. Utilizing a Sony ICX694 sensor complete with EXview technology for outstanding Quantum Efficiency and generous sky coverage, the 460EX is also one of the most versatile astrophotography cameras around. Well-suited to a huge range of telescopes from the amateur to the professional, it’s ideal for those looking to invest in a camera that will provide uncompromising performance, no matter where your astroimaging journey may take you.
EXview
What's in the box?
3-metre USB cable
- Sensor Type: CCD - Sony ICX694 /5
- Horizontal Resolution: 2749 pixels
- Vertical Resolution: 2199 pixels
- Pixel Size: 4.54 µm x 4.54 µm
- ADC: 16 bit
- Readout Noise: 5e- typical value
- Gain Factor: 0.27e-/ADU
- Full Well: ~18,000 e-
- Dark Current: ~0.0004 electrons/second at -10°
- Interface: Mini-USB 2.0 High Speed
- Power: 12v DC 1A
- Maximum Exposure Length: Unlimited
- Minimum Exposure Length: 1/1000 s
- Cooling: Termoelectric set point with max ΔT=-25°C
- Weight: approx. 400 gr
- Backfocus: 13mm ±0.5
- Available as mono or colour
System Requirements
- Pentium III PC with 128MB RAM
- CD-ROM drive
- USB 2.0 port
