Atik 428EX Mono [ATK-0096]
ATK-0096
$1,636.93 USD $1,925.80 USD
1 in stock On sale, save $288.87 USD IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Atik Cameras: The 2.8MP sensor of the Atik 428EX is ideal for astrophotographers looking for incredible sensitivity at a medium resolution.
While higher resolutions often come with increased download times and higher price tags, the Atik 428EX is versatile across a range of targets and imaging systems, while still providing an advanced performance capable of winning our 2013 Astroimaging Competition.
Features of the 4-Series
The slim, ergonomic design of these cameras naturally comes in at a low weight to help minimize stress on the corrector plate. The desiccant port is readily accessible from outside the camera for easy maintenance , and a simple 12V power requirement is complimented by low power use to help you get the most out of your imaging sessions, whether in the observatory or out in the field.
EXview
What's in the box?
3-metre USB cable
Quickstart guide (paper)
About Atik 428EX Mono [ATK-0096]
EXview
What's in the box?
3-metre USB cable
  • Sensor Type: CCD - Sony ICX674
  • Horizontal Resolution: 1931 pixels
  • Vertical Resolution: 1451 pixels
  • Pixel Size: 4.54 µm x 4.54 µm
  • ADC: 16 bit
  • Readout Noise: 5e- typical value
  • Gain Factor: 0.27e-/ ADU
  • Full Well: ~17,500e-
  • Dark Current: ~0.0002 electrons/second at -10°
  • Interface: Mini-USB 2.0 High Speed
  • Power: 12v DC 1A
  • Maximum Exposure Length: Unlimited
  • Minimum Exposure Length: 1/1000 s
  • Cooling: Termoelectric set point with max ΔT=-25°C
  • Weight: approx. 400 gr
  • Backfocus: 13mm ±0.5
  • Available as mono or colour
System Requirements
  • Pentium III PC with 128MB RAM
  • CD-ROM drive
  • USB 2.0 port
