RIDK 700F/7 Standard Glass Aluminum Carbon Optical Tube [OS-RIDK700SGA]
OS-RIDK700SGA
$87,412.62 USD
Officina Stellare: 95 mm manual FineFocus focuser (motor on secondary mirror already installed, add ATC-02 to use it), carbon/aluminum truss tube design, splitted light baffle, 7'' dovetail and a Losmandy on top for accessories, TC-01 three ventilation fans and mirrors heaters with manual control, shroud and cap covers.Primary cell detachable for an easy cleaning of mirror.
The results are simply amazing: a telescope that offers a wide, flat focal plane (more than 65 mm in diameter, even in the smallest model!). A wide focal plane that is diffraction limited over a wide spectral range.
Since the corrector group is close to the focal plane, chromatic aberration is undetectable.
About RIDK 700F/7 Standard Glass Aluminum Carbon Optical Tube [OS-RIDK700SGA]
  • ENTRY PUPIL DIAMETER - 700 mm (28")
  • FOCAL RATIO - F/3.8
  • FOCAL LENGTH - 2660mm (105")
  • LINEAR OBSTRUCTION - 55%
  • FULLY CORRECTED AND ILLUMINATED FIELD - 80 mm
  • WEIGHT - 140 kg
  • BACK FOCUS EXTRACTION - about 240 mm (9.5")
