ZWO ASI1600MM Monochrome astronomy camera [ZWO-ASI1600MM]
ZWO-ASI1600MM
$999.00 USD
ZWO Optical: ZWO ASI1600MM USB3.0 Mono Astronomy Camera. Resolution: 16Mega Pixels 4656×3520
Large format B / W camera, 4656 x 3520 pixels, usable in deep sky, planetary and autoguide mode - 16 million pixels. Very large field, fast and powerful.
The large monochrome sensor of the ZWO ASI 1600 MM camera has no less than 16 million pixels (4656 x 3520 pixels), which is used for astrophotography of deep-walled deep-field objects but also for imaging Planetary and even self-guided if needed.
This camera has a very high level of performance. Its sensor is both sensitive and has a very low level of thermal noise.
In planetary mode, its speed of acquisition reaches the rate of 80 images / second at the resolution of 640 x 480 pixels, which makes it one of the fastest on the market. This acquisition speed makes it possible to "freeze" the turbulence in planetary imaging and thus to obtain a final image provided with numerous details.
This acquisition speed can be pushed to 192 fps when used in 10 bit mode and lower resolution (320 x 240 pixels).
For autoguiding, the camera is equipped with a standard ST4 port, adaptable to a large number of commercial frames.
The ASI1600MM has a female M42 input thread (M42 x 0.75), but also a mechanical converter M42 to the 50.8 mm and 31.75 mm (2 "and 1.25") flowmeter, Adapt standard telescopes and eyeglasses to the standard eye-lenses.
A 2m long USB cable and a ST4 autopilot cord (also 2m) are also part of the package.
What’s in the box?
–ZWO ASI1600MM Camera Body (not includes the lens )
–T2-1.25″ nosepiece
–1.25″ Cover
–2 m long USB 3.0 cable
–2 m long ST4 guider cable
–T2-M48 extender 18.5mm length
–T2-1.25″ filter adapter
–Driver & Extra Software CD (Mac, PC & Linux Compatible)
About ZWO ASI1600MM Monochrome astronomy camera [ZWO-ASI1600MM]
What’s in the box?
–T2-1.25″ nosepiece
–1.25″ Cover
  • Width: 41 mm
  • Diameter: 62 mm
  • Sensor Type: CMOS - 12 bit Monochrome
  • Size of the sensor: 17.7 mm x 13.4 mm
  • Number of pixels: 4656 x 3520 pixels
  • Pixel size: 3.8 μm x 3.8 μm
  • Sensor: CMOS B & W - 4/3 "
  • Number of frames per second: Up to 192 frames per second in 320 x 240 pixel resolution
  • Autoguide: YES - ST-4 protocol compatibility
  • Connection: USB 3.0 and USB 2.0
  • A / D conversion: 12 bit / 10 bit
  • Cooling: NO (see model ASI1600MM-C)
  • IR Filter: NO
  • Compatibility: Prism 8, FireCapture, SharpCap V2.6, OaCapture V0.8.0.
  • Weight: 140 g
  • Flow: 50.8 mm and 31.75 mm (2 "and 1.25") / T2 (M42 x 0.75)
  • USB cable: Power supply: Length 2 m; Autoguiding: length 2 m
  • Minimum exposure time: 0.000032 seconds
  • Maximum exposure time: 33 minutes
  • Noise reading: 1.2e
  • Computers: Windows XP, Vista, 7,8,10 (32bits / 64bits), Linux, Mac OSX
  • Quantum yield: ~ 60%
  • Distance Chassis - CCD Sensor: 6.5 mm
  • Model: ZWO monochrome camera ASI1600MM
